- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I try to check-in a file from Inventor, it seems like Inventor is frozen. It is not that it is non-responsive, it is that none of the other commands will work. When I do an ALT+TAB to see all the open dialogs, I see this.
When I try to select this dialog, it will not let me. In order to clear this, I have to hit the "Windows" key and then it clears the dialog. Its not supposed to work this way. Here is what I have done (in this order) to try and make this work correctly, but nothing has worked so far.
1. Rebooted workstation
2. Disabled ALL add-ins.
3. Repair install on both Inventor and Vault pro.
4. Rebooted computer.
5. Inventor reset utility.
6. Rebooted Computer.
I suspect that this dialog above is this "Properties out of date" dialog:
I have checked the Inventor prompts (Tools>app options), but cannot find this prompt there. Also checked the Vault pro "Options" for this prompt, but no luck there either. If I can suppress this dialog, I would. I think that would solve my issue.
Any suggestions on how to solve this would be apprectiated.
Kirk
Inventor 2020.2.2
Vault 2020.2
P.S. Here is a screencast of me trying to check in a file.
