Help with my Turbocharger design.
Message 1 of 13
Im a few months into studying Mech Eng so naturally i am new to Inventor. Im in the process of trying to design a turbocharger and i keep getting stuck on the interior of the housing. I need the end of the loop to taper onto the turbine/compressor blade as opposed to hitting a wall and doing a 90°turn onto the wall. I think the direction of flow is paramount to the behaviour of force acting on the turbine. Ill post up pics explaining what i want to to do.
Replies (12)
Message 2 of 13
CCarreiras
HI!
No pictures, but anyway... it's better to post the ipt file...
CCarreiras
Message 3 of 13
Hey Carlos, i just uploaded the IPT file. I was gonna post up pics outlining/highlighting what i wanted to do, if the IPT file is all that is needed that would be great.
Message 4 of 13
CCarreiras
Hi!
Ups... no pic... no file...
What internet browser are you using?
try upload files with another Int. browser.
CCarreiras
Message 5 of 13
Part 1 last extrusion is a half finished failed attempt at finding a solution...Part 1.1 i deleted that last  extrusion
Message 6 of 13
I used google chrome
Message 7 of 13
CCarreiras
Hi!
The ipt File... And the pictures... ofcourse... nobody will guess what you need to achieve.
CCarreiras
Message 8 of 13
Were you able to open the file
Message 9 of 13
File looks fine. opened up, popped right into inventor.
Message 10 of 13
Frank, can you offer any solutions?
Message 11 of 13
Hey Frank, do you have any ideas on a solution?
Message 12 of 13
Ceboske,
Only what I had posted before, create the housing as a solid
and then use the shell tool, removing the opening surfaces. But to be
honest, you question seemed more like you were having problems with the
impeller, but the part file was the housing. For the impeller I would do a
loft on a curved path, then circular pattern. I would the place the impeller
in the housing in an assembly file and use the housing to trim the impeller
blades. Hope this helps.
Frank J. Nagle II
Mechanical Engineer
Summit Trailer Sales Inc.
Summit Station, Pa. 17979
570-754-3511 Ext.17
Message 13 of 13
CCarreiras
Hi!
You have to be clear in what you need...
I helped in this case below... maybe you can get some ideas...
Check here...
http://forums.autodesk.com/t5/inventor-general-discussion/loft-problem-in-reverse-engineering-applic...
CCarreiras
