Help with modeling techniques.
st32-22
Message 1 of 11
st32-22
How do I make it have angle like this or whatever it is, did I even do it right from start it looks fine to me besides that
Replies (10)
Message 2 of 11
89198826955
1. Building a sketch
2. don't forget about the center line
3.command "rotation"
Students are having exams  😁
Message 3 of 11
st32-22
Oh, so did I do it wrong? I should not have drew circles like this
Message 4 of 11
89198826955
you can create with circles
there are a lot of options for creating this part
Message 5 of 11
kacper.suchomski
Hi
You have at least 2 solutions:
  1. Use the Draft tool and draft the outer face of the chimney.
    https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-38133835-2EDB-414E-ACB1-2487A96900F7
  2. Use the Chamfer tool and create a draft from dimension+dimension or dimension+angle.
Kacper Suchomski
Message 6 of 11
st32-22
I used draft though I don't know if I did it right I wrote 12 like on picture when doing it, is it same like in example?
Message 7 of 11
st32-22
I think I fixed it now, it should be like in example am I right?
Message 8 of 11
kacper.suchomski
I think so. Use the measure tool and check that your dimensions match the graphics.
Kacper Suchomski
Message 9 of 11
st32-22
Okay, thank you so much I will accept your solution now
Message 10 of 11
SBix26
You can also add taper to an extrusion, like this:
I recall that you mentioned in a previous posting that you had very little experience reading drawings, and I want to point out that this drawing has a flaw in it that you should not repeat yourself-- it is over-dimensioned!  The base of the cone is dimensioned (28.5mm), and the height of the cone is dimensioned (30mm - 10mm), and the angle of the cone is dimensioned (12°), and the top of the cone is dimensioned (20mm).  Only three of those dimensions are needed to define the cone, any three will do.  The fourth is not only not required, it should not be shown at all unless it is marked as a reference dimension, which is done by placing parentheses around it.  Whoever created that drawing is guilty of disseminating bad habits to students.
Sam B
Inventor Pro 2024.0.1 | Windows 10 Home 22H2
Message 11 of 11
st32-22
Thanks!
