BASE OF THE FRAME-EXTRUSION NOT WORKING
jobinprovidence
jobinprovidence
I need help creating a base plate above the frame using the extrusion command. Despite several attempts, it's not working. Could someone assist me with a solution?
kacper.suchomski
Hi
Attach your project (pack all files first) if you can and describe what you want to achieve.
I will add - in the assembly environment, it is not possible to add material. The Extrude command (and others) is only for removing material - for example, creating holes and cutouts that must be made at the assembly stage and cannot be made at the manufacturing stage of the part.
Kacper Suchomski
SBix26
As @kacper.suchomski wrote, the modeling features in an assembly are only for material removal.  To create a new part you need to... create a new part.  Use the Create Component tool to start a new part in the context of your assembly.
Sam B
Inventor Pro 2024.0.1 | Windows 10 Home 22H2
johnsonshiue
Hi! I think Sam is right. The OP is trying to build body geometry at assembly level. Inventor's modeling approach is relatively strict. The body geometry is mostly within individual parts. At the assembly level, only cut features (machining) are allowed, except weld beads.
Many thanks!
Software Test Engineer
