Help with GD&T
Help with GD&T
cmmpro1
Message 1 of 12
Help with GD&T
cmmpro1
Good morning,
I am annotating a model and I keep getting errors while I am trying to do the GD&T. If I had a little more time, I would watch the videos but my time is short. can someone help me with this. Thanks!! I am going to post a screenshot of the problem I am having.
Replies (11)
Message 2 of 12
Mark.Lancaster
@cmmpro1
What errors are you seeing?  Are you talking about the ones that indicate the Tolerance Pattern and pattern count do not match?  Or something else?
Mark Lancaster
Message 3 of 12
Cadmanto
Yes,  please post screen shots.  I personally do the GD & T in the drawing, not the model.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 12
cmmpro1
Yes. The feature count don't match error. I will add a screenshot. Thank you for helping me!!!
Message 5 of 12
Mark.Lancaster
@cmmpro1
To follow up..  If you're talking about the message that's in the tolerance advisor about the pattern and feature, the reason is, this is an imported model.  The pattern doesn't exist..  Meaning the solid dumb and doesn't see the pattern or holes.   Smiley Wink
Update:  So the tolerance advisor is checking and doesn't see any feature pattern in the model.
Mark Lancaster
Message 6 of 12
cmmpro1
Thank you!! I thought something funky was going on. One more question... I see where I can retrieve the MBD GD&T annotations but it doesn't seem to work. When I click on the ribbon for that app, the box comes up but all the choices are grayed out. How do I fix that?
Message 7 of 12
Mark.Lancaster
@cmmpro1
Well first you need to select the correct tab..  Smiley Very Happy
Secondly, look at the dialog, its asking for you to select a view...  Smiley Wink
Mark Lancaster
Message 8 of 12
cmmpro1
Which means, I should probably place something on the drawing first!! LOL...... Ok let me try again...
Message 9 of 12
cmmpro1
I got that to work...... Now why don't the Hole and Thread feature don't work?
Message 10 of 12
Mark.Lancaster
@cmmpro1
You have numerous postings going on..  Please refrain from posting the same question https://forums.autodesk.com/t5/inventor-forum/hole-and-thread-app-not-working/m-p/7742905/highlight/... in different postings.
Mark Lancaster
Message 11 of 12
Cadmanto
After you place your views you need to go under the Annotations tab and select what's shown below.
Best Regards,
Scott McFadden
Message 12 of 12
Cadmanto
Because it is a dumb solid, it is not recognizing any point sketches to place holes or threads.
Best Regards,
Scott McFadden
