@Anonymous wrote:
Now what if I need to change it to a different thickness?
Why would you need to do that?
I'm going to assume you are a sheet metal fabricator and the step file is customer supplied..
If the customer would like it in a different thickness then they should submit a corrected step file..
However if you really need to change thickness I would use "thicken" from the 3d model tab in the modify section..
You can also use the direct edit tools and some other ways..
As its a "dumb solid" its not going to respond to changes in the Sheet metal defaults dialog but you need to set that to material thickness to allow it to "search for" and unfold the part.
