Help PLEASE!!!
Help PLEASE!!!
Message 1 of 29
Help PLEASE!!!
I am somewhat new to Inventor, and for school I need to make a checkerboard. My teacher says he would make a bunch of squares all on a single base, and extrude them all by 1/32, 2/32, and so on, stopping at 8(it is a 8 square by 8 square board). I have had problems extruding just one square, and was wondering if there is an easier way to make this. Please help! I need this done tommorrow morning!
Replies (28)
Message 21 of 29
I do not have another computer with autodesk installed, so should I just reinstall it?
Message 22 of 29
JoyceZhou
You could also check with your classmates whether anyone has the same OS and have the same version Inventor installed.
If no one has same setting as you, then please try to reinstall it.
Joyce-Jinghua Zhou
Inventor QA Engineer
Message 23 of 29
Ok, thank you!
Message 24 of 29
I am almost done re downloading, will be ready soon
Message 25 of 29
TheCADWhisperer
Survivor comes on in 15 minutes - I'll catch up with you in the morning.
Message 26 of 29
ok, 8 AM central time
Message 27 of 29
Curtis_Waguespack
Hi 2020jhh1,
Here is a quick video showing one method to do this.
I hope this helps.
Curtis
Message 28 of 29
Curtis_Waguespack
And here's another take on this that is maybe a bit more simple. It uses the combine tool to "inlay" the black squares into the base.
Message 29 of 29
This helped SOOO much!!!! You are a life-saver, thank you!!
