Hi
I'm new to the Dynamic Simulation and have been trying to use it to justify the force required by the cylinder to rotate the arm. It seems such a simple assembly but having watched all the You Tube video's I can find, I can't understand why I have joint errors.
The assembly has no constraint errors and behaves as expected when dynamically dragged.
I have set a time of 2 sec and the cylinder moves from 100mm (extended) to 0mm (retracted)
I keep having a joint error which I can't seem to fix, which I think is preventing me from selecting a Joint for a Jack within the Unknown Force command.
If anyone could take a look and point me in the right direction it would be appreciated, as i'm out of idea's
Data is Inventor 2020.
