Help needed with simple Dynamic Simulation
nick_parry
Message 1 of 10
nick_parry
Hi
I'm new to the Dynamic Simulation and have been trying to use it to justify the force required by the cylinder to rotate the arm. It seems such a simple assembly but having watched all the You Tube video's I can find, I can't understand why I have joint errors.
The assembly has no constraint errors and behaves as expected when dynamically dragged.
I have set a time of 2 sec and the cylinder moves from 100mm (extended) to 0mm (retracted)
I keep having a joint error which I can't seem to fix, which I think is preventing me from selecting a Joint for a Jack within the Unknown Force command.
If anyone could take a look and point me in the right direction it would be appreciated, as i'm out of idea's
Data is Inventor 2020.
Replies (9)
Message 2 of 10
WHolzwarth
DS is more critical than Inventor's constraint solver.
Constraining of the cylinder sub-assy is better with an insert constraint at the top (right now), but the other should be changed to only a mate between the axis of the arm's end and the center point of the rod end.
This is transferred as a Point-Line Joint in DS, and seems to work better now.
Walter Holzwarth
Message 3 of 10
nick_parry
I've altered the assembly constraint as suggested
I've locked the d.o.f 2 (R)  in the new Point Line Joint - That now runs & appears to be stable - So thanks for that.
I can now apply an Unknown Force - Jack.
I've used a face on each Hex Nut at each end of the Cylinder - So the Arrows Appear opposed in the direction of the Cylinder.
How do I obtain a predicted force required from the cylinder.
The Output Grapher result is a constant force. The cylinder force will vary over the path.
Do I have to use the Unknown Force command can it be read from the force plot on one of the current Joints.
Message 4 of 10
WHolzwarth
I didn't test it with your files, but perhaps this link can shed some additional light:
https://forums.autodesk.com/t5/inventor-forum/graph-hydraulic-cylinder-load/td-p/2547428
Walter Holzwarth
Message 5 of 10
JDMather
Can you Attach the altered assembly?
Message 6 of 10
nick_parry
I've attached the updated data.
I notice you recommend a book by Wasim Younis - I think this will be a valuable read.
Message 7 of 10
j.palmeL29YX
Notwithstanding some possible (and to recommend) improvements:
Running your Simulation2 I get >>this<<
The result seem to be plausible. What is your problem?
(The locked Rotational degree of freedom MAY cause problems. In your model it doesn't)
Jürgen Palme
Message 8 of 10
nick_parry
Thank you Jürgen
I couldn't find where to display the force results for that joint.
Lack of experience with D.S
Your screen grab helped greatly.
Message 9 of 10
j.palmeL29YX
>>Here<< some suggestions how to improve the quality of your DS.
(One of the basic rules in DS: While defining joints use origin planes, origin axis' and/or origin points of the components as often as possible)
If my reply solves your problem, click the "accept as solution" button. This can help others find solutions faster
Jürgen Palme
Message 10 of 10
WHolzwarth
I wouldn't change the Cylindrical Joint in DS to Prismatic, Jürgen.
The piston rod normally moves cylindrical versus the cylinder's body, and placed at it's end is a ball joint system.
Walter Holzwarth
