Inventor Forum
Help: iProperty populate iLogic
3 REPLIES 3
1093 Views, 3 Replies
I am trying to use iLogic to automatically populate an iProperty value based on the dimensions of the flat patterns. I want the formatting to read as Length X Width. Currently I have the following:
If component_type="standard" Then
iProperties.Value("Custom","TOTAL MATERIAL USED")=Round(extents_width, 0)" X "Round(extents_length,0)
Else
I am getting:
Error on Line 11 : End of statement expected.
Error on Line 13 : End of statement expected.
I'm guessing this is due to using the " X " or having multiple parameters in the same line. If anyone knows the right way to structure this I would appreciate any help you can give.
Also, if there is a way to make these values multiplied by the quantity of parts in an assembly drawing bom to get total stock used that would be very helpful.
EDIT:
Simplified Code:
extents_length = SheetMetal.FlatExtentsLength
extents_width = SheetMetal.FlatExtentsWidth
iProperties.Value("Custom","TOTAL MATERIAL WIDTH")=extents_width
iProperties.Value("Custom","TOTAL MATERIAL LENGTH")=extents_length
iProperties.Value("Custom","TOTAL MATERIAL USED")=extents_width" X " extents_length
Now getting:
Error on Line 5 : End of statement expected.
3 REPLIES 3
jtylerbc
I'm not certain of the syntax to do exactly what you're trying to do.  However, I can propose an alternative that may be easier.  I believe you can fix this in the custom iProperty itself.
For the value of the TOTAL MATERIAL USED property, type the following iProperty expression:
=<TOTAL MATERIAL WIDTH> X <TOTAL MATERIAL LENGTH>
Then, remove the TOTAL MATERIAL USED line from your iLogic rule altogether.
Yijiang.Cai
Generally we need to add the "&" for the string connected. Please see them below -
iProperties.Value("Custom","TOTAL MATERIAL USED")=Round(extents_width, 0) & " X " & Round(extents_length,0)
Else
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
jtylerbc
in reply to: Yijiang.Cai
That's what I thought and was going to suggest yesterday.  Couldn't get it to work at the time - not sure what I was doing wrong then, because it works fine today.
Technology Administrators
