Hi group.
Will someone please try this test and let me know what you get?
(1) Create an assembly and assign all the correct iproperties (especially custom) to it.
(2) Bring the assembly into a presentation view (.ipn). You can explode it if you wish but it is not
necessary for this test.
(3) Now create a 2D drawing using you .ipn file. Do your custom properties and other properties
populate the title block as they should? If so, how do you do it? I can not make it work.
Thanks.
Mike
