Inventor Forum
Helix thread
4 REPLIES 4
drawingsCHR7R
766 Views, 4 Replies
Helix thread
Hi guys,
I'm looking for some suggestions as to what a good workflow would be to get a helix around this ground screw so that it can act as a large thread, my issue is I am not sure how to get the helix to follow the profile of the body that it has to go around.
Thanks guys.
4 REPLIES 4
JDMather
in reply to: drawingsCHR7R
Do you have an image of a similar real-world part (is the screw tapered to a point or is it constant radius OD)?
Something like this?
drawingsCHR7R
in reply to: JDMather
Hi JD,
It has a taper. Here are a few pics of the model I am using.
kelly.young
Hello @drawingsCHR7R here is a collection of posts that contain part examples that could be helpful.
How to create a tapered coil screw auger with the same Inside Diameter (ID) from end to end using In...
There are methods using a Coil as Surface and Project Geometry to it then Thicken.
Please select the Accept Solution button if a post solves your issue or answers your question.
drawingsCHR7R
in reply to: kelly.young
Thank you, I will definitely have a look!
