Helix Pattern on Assembly
Message 1 of 17
Sorry if this question is already answer in some post, but i search and i didn't find anything.
I want to create a Helicoidal Winding and then i want to put 16 pieces around the top face of helicoidal winding. The idea is that the piece and the winding should be together, like we make a "mate" between the face of the piece and the top face of the winding.
I attach some photos so you can see.
Thanks for the time and help.
Accepted solutions (3)
Replies (16)
Message 2 of 17
JDMather
Use a curve driven pattern of workpoints on the helical face and then pattern component.
Attach your assembly here if you can't figure it out.
Message 3 of 17
I attach here the file!
Thanks!
Message 4 of 17
Thanks!
Message 5 of 17
JDMather
I do not have an rar extractor - I prefer to keep my Inventor machine squeaky clean.
See Post #8 in this thread for similar example.
Message 6 of 17
johnsonshiue
Hi! Like JD shown in the video, this can be done by feature pattern based component pattern. Please take a look at the video carefully. That is the exact workflow to use. Basically, you need to create a workpoint at the bottom of the Helicoidal part. Then use Rectangular Pattern command to pattern the workpoint; the direction should be one of the helical edge at the bottom. After that, go back to the assembly. Use Component Pattern command and select Calço de Enfiar. In the first tab -> click on Feature Pattern Select button -> pick the workpoint pattern from Helicoidal. You will get the component pattern following the feature pattern.
Many thanks!
Software Test Engineer
Message 7 of 17
But my idea its to do that in a IAM file and with a pattern where i can change the number of itens and the distance between the first piece and the last piece.
Can someone of you do that in my files please?
Message 8 of 17
Can you please use my files above and show me your solution?
Or there is another solution to this problem?
The idea is not to have a workpoint in another feature but in work plan ou a axis.
Thanks for the time!
Message 9 of 17
JDMather
While you wait for someone to present the solution - I recommend that you install the Updates for you version of Inventor.
Message 10 of 17
johnsonshiue
Hi! As we mentioned before, it can be done easily by using Feature-Pattern Driven Component Pattern. See attached file.
Hi JD,
There is an open-source zip tool called 7zip. It is very capable. It can read almost all well-known compressed file formats like rar, zip, and so on. We use it quite extensively.
Many thanks!
Message 11 of 17
Is exactly this that i want.
But i'm having problems to do exactly like you did.
Can you explain to me by steps how you did this?
Sorry for the time, and thanks!
Message 12 of 17
johnsonshiue
Hi! What I did was pretty straight forward. Basically, you need a pattern on workpoints following an edge. In your case, the span of the component pattern does not run all the way along the helical path. There is an offset at the start and end. I create a zero-offset surface on the inner face. Trim the surface so that it accommodates the offsets I mentioned earlier. Next create a workpoint. on a vertex. Then pattern the workpoint along the surface edge. That is pretty much all you need to do within the part. Return to the top and pattern the small clip by selecting the workpoint pattern in the part.
Many thanks!
Message 13 of 17
Hi again,
I still need help, because i can't do like you did! Sorry for all these questions, but it's possible to do a video, or explain me by steps what i should do?
I will appreciate so much if you can help me a little more!
Thanks again for the time and i'm sorry one more time for this situation!
Ricardo
Message 14 of 17
S_May
Message 16 of 17
Thanks for the help!! I now understand how to do!
But i have one more question, let's imagine that we don't have the coil, and we only have the piece we want to do the helix pattern.
In that case we should have a parameter in the turn height.
How we can do this, with a 3D sketch it's possible? or there is another way?
One more time, thanks for the time!
Message 17 of 17
S_May
