Inventor Forum
having trouble with solid body in inventor
4 REPLIES 4
christianJTJLC
277 Views, 4 Replies
hi guys, im new to the forum, so hello to everyone.
im hoping someone can help me out with this little problem im having in inventor 2017.
i spent quite a lot of time designing a part, and the machinist required the drawing as an xt file. so i saved a copy in xt format. the problem is that now my ipt part doesnt have any features, its just a solid body, and i would like to edit a certain aspect of it.
is there any way i canexpand all my workflow back into the ipt part?
sorry if this sounds a little dumb, im kinda new to inventor.
Thanks in advance
christian
4 REPLIES 4
Hi christianJTJLC,
If you create a part in Inventor and save it as an *.ipt file first, and then export it as an *.x_t file, then the *x_t file will be a "dumb" solid, but you can open your original *.ipt file and edit the feature and sketches still.
I hope this helps.
Curtis
Hi Christian,
Welcome to Inventor family! There is no dumb question here. Occasionally you might see dumb answers, particularly from me. If you are a subscriber, you can sign into subscription account and download Feature Recognition tool. It helps converting imported body to some features.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=9172877436288348979&appLang=en&os=Win32_64
Many thanks!
Software Test Engineer
Thanks guys, i think what i did wrong was that i saved copy as xt, instead of exporting an xt, so my original ipt became "dumb".
but i sorted it out pretty quickly. i had saved a 2d dwg earlier, so i could redraw the part pretty quickly from that.
cheers!
@christianJTJLC wrote:
Thanks guys, i think what i did wrong was that i saved copy as xt, ...
Nothing wrong with that workflow, that is what I would have done as well, but you also need to save the *.ipt file.
Saving one has no effect on the other.
Technology Administrators
