having trouble with pink dimensions
Message 1 of 8
Dear community,
i have been having trouble making drawings since every time i put in dimensions and later have to alter the model the dimensions just wont
adjust to the new situation (see attached image).
my question is if there is a way to better ''lock'' or ''constraint'' the dimensions onto model features or something so when i for instance change the diameter of a pipe it changes with the new size.
Replies (7)
Message 2 of 8
Rob67ert
Hi there,
Is this an iPart or iAssembly?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 8
this is an ipart (multi body part) placed in an assembly
Message 4 of 8
Rob67ert
This will happen if you change the iPart in the assembly.
For the dimension it will be a different part, so it is not able to connect the dimensions the the geometry.
Robert
Message 5 of 8
is there a way to work around this ?
Message 6 of 8
Rob67ert
It depends on the geometry that will change in the different iPart members.
For instance, if you have a hole in one member and put a dimension on it, the dimension will ben pink if you choose another member without that hole.
Robert
Message 7 of 8
In this case the roof nozzle only moved a bit to the left, where as all connected dimensions stayed behind
Message 8 of 8
Prav!n
You could not "Lock" or "Constrain" a dimension with respect to a Model/Geometry.
You can be able to Constrain Ur Views (Detailed / Sectional) with respect to the Geometry.
For Detail View:
Right Click and Select "Attach" to Lock the View Boundaries. So that if u r moving or updating the sizes it auto-populates itself.
For Sectional View:
Right Click and "Edit", Using Project geometries constrain it with the section line.
This could help you a little.
S.Praveen
