I drew a part in inventor pro and then I did a stress analysis in the software, the software generates a folder which contains the files and results for the stress analysis. However, after I deleted the folder, every time I launch the software it tells me that the files are missing and I had to skip and skip and skip until it drawing finally appears. I would like to know how I can stop the software from popping these messages on startup.
Solved by Gabriel_Watson. Go to Solution.
If you delete the folder, the study still exists in the component and is looking for the data. Just skip and open the file, go into the stress analysis and delete the study. Should fix it.
