Would be easier if you upload an example, but the following might work for you.
Option1: Save a copy of the file, delete one end, repeat for the other end and combine them in a assembly.
Option 2:
Use sculpt to convert the surface model to a solid model, do this 2 times so you end up with 2 solids, then use direct edit to increase the spacing.
