hatch patterns cann't be print
Stakin
Stakin
inbventor version. :Inventor 2016
I had installed the update2 for inventor 2016,but it still cann't output some hatch patterns, such as AR-CONC.
Is there any way to fix it?
if hatch pattern is ANSI 31,it can be printed,such as :
but if the hatch pattern is AR-CONC,AR-CONC screen.png.
the AR-CONC cann't be print.
thanks
Mark.Lancaster
This is a known issue and will be resolved in service pack 1 (when it comes out) for Inventor 2016.
Mark Lancaster
Stakin
I got it,thank you very much!
Paul-Mason
 "This is a known issue and will be resolved in service pack 1 (when it comes out) for Inventor 2016."
This is all we've had from Autodesk for over SIX MONTHS NOW the TOTAL LACK of action to correct this is getting ANNOYING and the same old reply is getting BORING
With one workaround that is to print/export to PDF then print thae PDF, but this unnecessary extra work
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
Stakin
Hi, Mason-Paul
Thank for reply with great Patience J
I tried the way to print/export to PDF,but cann??t print either.
Is any way else?
Tahnks again.
?廪??ѧ??????????Դ?????о?Ժ
??Ӧ?ѽṹ?о??ң?104?ң?
???䣺yanhj@tsinghua.edu.cn
?绰??+86-10-62784824-8011
?ֻ???13810811203
??ַ?????????廪??ѧ?ܿ?¥B??401????
?ʱࣺ100084
Paul-Mason
Some once suggested exporting to DXF or was it DWF can't remember.
But I'm having no problem exporting to PDF with ALL the hot-fixes etc installed.
Inventor 2026 Pro
Xeon
Stakin
thank you very much ,paul
I save it as AutoCAD dwg, and all the hatch pattens are ok,
but,
the Multitext  line spacing becomes large.
