Is there a way to re-align hardware with a tweek line in a drawing? (see attached) In this assy a hardware group is separated at the panel, The screw is still in line with the hole but it appears the tweek line has moved. Normally I would just change the visibility of rhe tweek line and add the line back as a sketch line. I just wondered if there is another way of doing this without having to create a sketch? Thanks for the help.
