Handle need to develop in sheet metal
dinisaran
dinisaran
Hi, its a handle part developed in solidworks, need to develop the same in inventor, any steps or method would be fine, expecting suggestion or step by step guidance to develop in inventor
Replies (8)
YannickEnrico
First of all, the part needs to be drawn so it has faces. That can be done with contour flange.
Afterwards, you choose the inner face before pressing "Create Flat Pattern"
On a part that has multiple directions in which the Thickness is the sheet metal thickness, you can get multiple different unfolds. Hence you need to select the stationary reference for the flat pattern.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2024 Professional
YannickEnrico
You can put on fillets, but you need to make sure you keep a part of the face
hence I made the fillets 3,99 instead of 4,0 in this attached screenshot
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
kacper.suchomski
Hi
Look at this:
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
dinisaran
Thanks for the response will work out and let you know
dinisaran
Thank you for the video has worked out and able to get the output, but still i have a query based on this video have tired out, but we are not getting flat pattern details if we work out on this option https://www.youtube.com/watch?v=3Mo6oEmJENg how to get the flat pattern details in the drafting
kacper.suchomski
You are confusing concepts. To obtain a flat pattern, it is necessary to tear the material (even minimally).
Kacper Suchomski
kacper.suchomski
You can go a different route and make a hold with FG. You will get the nominal length in the drawing in the BOM.
Kacper Suchomski
YannickEnrico
Keep in mind my approach is based on round steel bar and Kacper's is based on pipe or sheet metal to be rolled into a pipe.
Either approach can work, but of course it depends on your base material.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
