Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Graphics problem when using section view
Hi all,
Issue when doing section views in the model. After I create the view I get the attached problem big gray box. it is not just the cross section of a plate because nothing is there in the normal model (see the last pic). I can move around the assembly and it doesn't go away. Now I have been able to get it to go away temporarily by changing the visual style but usual comes back after a few minutes of moving around the model.
Replies (7)
Fouad-l
Hi.
Please tell us which version of Inventor do you use (service pack) and if it is posible attach your design to help you better.
While, you can check this  :
change the graphic mode to Compatibility and restart inventor.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Here is the info
Also this is project independent. it happens on almost anything im working on that has more then a few assemblies.
johnsonshiue
Hi Paul,
This issue has been resolved as of 2017.4 Update. If you have access to subscription site, please download R4 Update and install it. The issue should go away.
Many thanks!
Software Test Engineer
Andrew_Mayman
The issue reappeared in 2018 for me, but that being said, I've only had it occur once in the last 2 weeks.
Andrew.
Xeon E5-1620 v3 @3.50GHz
32Gb
Quadro K4200 (375.86)
Kudos is much appreciated if the information I have shared is helpful to you and/or others
Did this resolve your issue? Please accept it "As a Solution" so others may benefit from it
johnsonshiue
Hi Andrew,
The issue should be 2017 specific. If you are seeing it on 2018, something is not working right. Please let me know if you have repeatable steps in 2018. We need to take a look at the behavior.
Many thanks!
