Graphics Card for Inventor
lkirit2000
Advisor Advisor
Message 1 of 17
lkirit2000
Hi
I am trying purchase a laptop for inventor and solidworks.
The only puzzling thing is graphics card. The followings are available
1. NVDIA T500
2. NVDIA RTX A2000
3. NVDIA RTX A1000
4. NVDIA gEfORCE RTX 3060
5. NVDIA QUADRO K4000M
Please advice and let me know which is available?
What about the following model
https://www.hp.com/au-en/shop/laptops-tablets/laptop-gaming/omen-laptops/omen-gaming-laptop-16-k0078...
Replies (16)
Message 2 of 17
johan.degreef
I would go for the cheapest one, as it is the CPU that is most crucial. Invest the saved money in a faster CPU.
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Message 3 of 17
CCarreiras
If the pc is only for professional work, i suggest an workstation. NVidia quadro series works in a different system (Open GL) them game cards (direct x). These pc's are more stable, robust, and last longer,,, and they are way more expensive.
If it's for your personal use... t you want to play games, multimedia and some CAD, it's better the gaming PC. (Any recent RTX will work).
You don't need to buy the most expensive unless you have the money available and you want to have the most recent (sometimes not the best).
The important is:
  • sd disk
  • 64Gb ram (or more)(32 will work)
  • Graphic card Nvidia (not other brand in my experience)
  • Good processor
CCarreiras
Message 4 of 17
cadman777
Nothing has changed with Inventor and SW since 2 decades.
Search through the forums to find lengthy discussions on this topic.
When your mind is 'filled up' with knowledge, then you can make a good decision.
It may take you a day of reading to learn what you need to know.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 5 of 17
Gabriel_Watson
If you can find those, check what is closest to each setup here:
https://invmark.cadac.com/#/
Message 6 of 17
Frederick_Law
First: both works with OpenGL and Direct X.
Second: IV had switched to Direct X for a long time.
IV (and other CAD) had so much problem with Open GL AutoDesk recoded it to use DX.
Way more stable since then.
Message 7 of 17
CCarreiras
Quadro uses OpenGl from hardware and directx with software emulation.
...and Geforce is the opposite.
I was referring to CAD systems, in general (several programs, not only Inventor), but i have to agree that nowadays inventor works well (maybe better)  using directx.
Anyway, maybe a workstation is not even faster than a gaming pc, but has a stable behavior, and for me, that's important not to lose work because PC is shutting down when doing exigent tasks.
CCarreiras
Message 8 of 17
Frederick_Law
Do you have a source for that information?
Just for my personal enlightenment 😉
Love the days when I can mod a GeForce to Quadro.
Message 9 of 17
CCarreiras
Just google it.... 😅
https://www.asus.com/us/support/FAQ/1041353/
CCarreiras
Message 10 of 17
cadman777
@Frederick_Law
How did you do that?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 11 of 17
Frederick_Law
https://3dstudiouk.wordpress.com/2012/06/11/nvidia-geforce-to-quadro-soft-mod/
Some can be Soft Mod. Change hardware ID so driver think it's a Quadro.
Some need Hard Mod. Resolder a few resistors to change HW Id. Flash Quadro BIOS.
I had a few soft and hard mod cards.
A Quadro with TV tuner 😜
So technically, there is nothing physically prevent GeForce from working as Quadro.
Back then, a real Quadro can open more IV windows than a modded one.
You might caught news about fake RTX or Quadro with just a BIOS flash.
With current GPU using multiple CUDA cores, the different is even less or non.
It's all in BIOS and driver.
Message 12 of 17
Frederick_Law
I'll borrow Neil for a while:
https://www.youtube.com/watch?v=jT6YwF7NUSk
Message 13 of 17
cadman777
Thanx for the info, I'll check it out.
I used Quatro cards in the past, but they got way too expensive so I went to GeForce.
But the GeForce has problems, so I want to go back to Quatro, but can't afford it.
Maybe this is a possible remedy?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 14 of 17
Frederick_Law
What kind of problem? Crash? Graphic? Performance?
I used IV and SW on my laptop with Intel Graphic.
I set graphic setting to performance. Even when I have RTX or Quadro.
Using P1000 at work now.
Most company IT will buy low end Quadro because it's "recommanded".
Message 15 of 17
cadman777
It's a desktop workstation.
It doesn't show the views as good as the Quatro.
They 'orbiting is 'jerky' when the model is large.
Part sketch dimension text has a large gap on both sides of the dimension and dimension lines.
But that disappears and it works as expected when I activate the sketch.
So I learned to live with it.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 16 of 17
lkirit2000
Hi Team,
Thanks for your advise.
What is difference between NVDIA T500 vs NVDIA Geforce RTX 3050?
Which good for 3D CAD modelling?
Message 17 of 17
cadman777
Here is a website you can use to make determinations on graphics cards performances.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
