Hello everyone
Check out picture
I've had this strange error twice recently. It was still possible to work with it and save.
The only way to get that fixed, is to shut down Inventor and start again.
I ckecked all the graphic options and driver too, I even exchanged that with others and than still happened again.
Just wondering if someone has ever had something like that
Thanks a lot
Does it only happen with this particular part or with any file?
it happens with any parts and i'm not the only one, two other collegues experienced the same
and it has only happened with .ipt files so far
Then you need to look for things that A) you and you colleagues have in common in your setups and B) the files you open.
The part you show in the image is obviously derived from a more complex assembly (did you convert from a STEP maybe?). Does this happen with "normal" IPTs as well?
Which Inventor version are you running and is it possible for you to share the file for others to test?
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
