Grabbing File Name & Path of Components from Assembly using iLogic
felix.cortes5K3Y2
Message 1 of 18
felix.cortes5K3Y2
Hi all,
I am attempting to write a piece of code that will search the assembly for any part number beginning with "19-0189-W" inside each assembly, however, I am running into issues. So far, here's what I got in my code
Dim oAsmDef As AssemblyDocument
doc = ThisDoc.Document
Dim oComp As ComponentOccurrence
oComps = doc.ComponentDefinition.Occurrences
Dim FileNameandPath
For Each oComp In oComps
	'FileNameandPath = oComp.????????
Next
For the FileNameandPath line, I do not know how to follow it up to get the path and file name. I've tried oComp.Definition.PathAndFileName but that does not work.
Once I have the FileNameandPath, I would like to do an IF statement to see that if the file name begins with "19-0189-W" then to store that file name.
Best regards,
Felix
Replies (17)
Message 2 of 18
mcgyvr
Something to get you started..
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
    Dim oName As String
    oName = oOccurrence.Name
    MessageBox.Show(oOccurrence.Name, "Component Name")
Next
Message 3 of 18
Sergio.D.Suárez
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim doc As Document
Dim searchTerm As String = InputBox("Search text in Part Number", "Find text", "Default Entry")
For Each doc In openDoc.AllReferencedDocuments
    Dim oPartNumber As String = doc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
    If InStr(1, oPartNumber, searchTerm) > 0 Then
	MessageBox.Show(doc.displayname, "FileName")
	MessageBox.Show(doc.fullfilename, "FullFileName")
	End If
Next
Hi, this code searches for a text in each of the reference files of the assembly file or drawing file, if it exists it will return the file name. I hope it helps to solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 4 of 18
felix.cortes5K3Y2
Just ran the code. Is there a way to give a count those occurrences in that If statement?
I would like to get a count of the number in that assembly
Message 5 of 18
mcgyvr
Dim doc As Document
myCount = 0 'create a counter
	myCount = myCount+1 'if found increment counter by 1
	MessageBox.Show(doc.DisplayName, "FileName")
	MessageBox.Show(doc.FullFileName, "FullFileName")
	MessageBox.Show(myCount, "Count")
	End If
Next
Message 6 of 18
felix.cortes5K3Y2
What if I wanted to count the number of occurrences for each part number?  For example, I have the following parts,
11002-W-001
11002-W-002
11002-W-003
When I hit search 11002-W with the tool you provided, I get all of these to successfully show up in my Inventor interface.
I have multiples of 11002-W-002 inside my assembly. How could I count the number of 11002-W-002 inside my assembly? I imagine this could be done inside the IF statement.
Thanks a ton Sergio,
Felix
Message 7 of 18
Sergio.D.Suárez
The rule that we were accommodating with @mcgyvr  searches all file references can be these parts within subassemblies, subassemblies
I ask, do you want to get the number of individual parts of the bill of materials? if you need this we have to make another approach through the assembly BOM
Mechanical Designer
Message 8 of 18
felix.cortes5K3Y2
Whoops! I thought it was you in the last message, didn't realize it was @mcgyvr. No disrespect intended!
We'll, I'd like to get a list of all the used Sub Assemblies that are being shared across each assembly. I don't think a BOM does a great job in that and it's a bit slow to load. So far, I think this method is extremely much quicker and would complete the purpose if I knew how to write a piece of string that could count all the occurrences of a specific 11002-W-002 inside the assembly, which is distributed in different assemblies.
Thank you both to @mcgyvr   and @Sergio.D.Suárez
Felix
Message 9 of 18
mcgyvr
@felix.cortes5K3Y2  How about this..
	oName = oComp.Name
	If oName.Contains(searchTerm)
	MessageBox.Show(oName, "Component Name")
	End If
Next
If myCount = 0
	MessageBox.Show("None Found", "None Found Message")
	Else
		MessageBox.Show(myCount & " of " & searchTerm & " found", "Found This Many")
End If
Message 10 of 18
felix.cortes5K3Y2
With the new code, every time I do a search of 11002-W, it gives me none found where as before it would successfully display the component file
Message 11 of 18
mcgyvr
I made assumptions I shouldn't have..
Update coming soon to check for filename not component name..
Message 12 of 18
mcgyvr
@felix.cortes5K3Y2
How about this one?
	oName = oComp.ReferencedDocumentDescriptor.FullDocumentName
	End If
Next
If myCount = 0
	Else
End If
Message 13 of 18
felix.cortes5K3Y2
Hmm still not working. I noticed that the first code would tell me each occurrence inside each sub assembly.
This second code only searches on the top level assemblies and not inside each assembly
Also, I was hoping to do a count for each individual assembly. When I do a search of 11002-W, it returns all the assemblies with a prefix of 11002-W and I would need a count of each individual assembly found in that search.
Thanks a ton,
Felix
Message 14 of 18
felix.cortes5K3Y2
I wrote this piece of code because I think it'll give the result I want, however, I have a problem with the strings in the line highlighted in red. I'd like to check the quantity of each filename produced by then searching that exact file name in the assembly
Dim doc As Document
Dim QTY As Integer
Dim FileName As String
Dim searchTerm As String = InputBox("Search text in Part Number", "Find text", "Enter Prefix Entry")
	FileName = doc.displayname
'	Messagebox.Show(FileName) ' SUCCESS
		For Each FileName In openDoc.AllReferencedDocuments ' THIS LINE DOES NOT WORK
			QTY = QTY + 1
			MessageBox.Show(QTY, FileName)
			Next
	End If
Next
Message 15 of 18
Sergio.D.Suárez
Hi, I do not take it as a colleague offense, on the contrary, it's an honor for me to collaborate with @mcgyvr , look at your level, I've learned a lot from your contributions, it's one of my teachers in this forum!
Returning to the problem in question here I send you another code, it is probably incomplete, but it may help you to add things. It is another approach, accessing the BOM and trying to capture the quantity of the row, if it is an assembly, it will look for the assembly in "model data" and if it is only part it will search in "only parts"
Sub main
Dim doc As Document
	Search_Doc(doc)
	End If
Next
End Sub
Sub Search_Doc(doc As Document)
Dim oModelname As String = doc.DisplayName
Dim oDoc As Document
oDoc = ThisDoc.Document
		Dim oBOM As BOM
		oBOM = oDoc.ComponentDefinition.BOM
		    ' Set the structured view to 'all levels'
		oBOM.StructuredViewFirstLevelOnly = False
		    ' Make sure that the structured view is enabled.
		oBOM.StructuredViewEnabled = True
		    ' Make sure that the parts only view is enabled.
		oBOM.PartsOnlyViewEnabled = True
		If doc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
		Dim oBOMView As BOMView
		oBOMView = oBOM.BOMViews.Item(1)'BOM Model data
		  Call ListItems(oBOMView.BOMRows, 0, oModelname)
		End If
		If doc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
		oBOMView = oBOM.BOMViews.Item(3)'BOM only parts
		End If
End Sub
Sub ListItems(Rows As BOMRowsEnumerator, indent As Integer,oModelname As String)
Dim oBOMRow As BOMRow
For Each oBOMRow In Rows
	Dim rDoc As Inventor.Document
	rDoc = oBOMRow.ComponentDefinitions.Item(1).Document
	Dim rDocName As String = rDoc.DisplayName
	If rDocName <> oModelname Then
	    If Not oBOMRow.ChildRows Is Nothing Then
	        Call ListItems(oBOMRow.ChildRows, indent + 1,oModelname)
	    End If
	Else
		If rDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then oType = "Assembly_Quantity: "
		If rDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then oType="Part_Quantity: "
		oQty = oBOMRow.ItemQuantity
		MessageBox.Show(oType & oQty  ,"Total quantity")
	End If
Next
End Sub
 I hope it helps to solve the problem
Mechanical Designer
Message 16 of 18
felix.cortes5K3Y2
Hey thanks for getting back at me!
I ran the code on VBA but it gives me an error on the 3rd line saying: "Compile error, Invalid use of property". It points to the line that says openDoc = ThisDoc.Document
I really want to try your code out but it won't run.
I was trying to add some lines to one of the first codes you provided and I think it should theoretically work but I cant find the syntax to do it. On the line highlighted on red, I get a quantity of the complete number of files inside the assembly and not the quantity of that file name inside the assembly.
What I need to do is find that syntax that would search each individual item in the browser instead of searching each file inside the assembly. This is what I written:
Dim openDoc As Document = ThisDoc.Document
Dim doc As Document
Dim innerdoc As Document
Dim qty As Integer
Dim InnerFileName As String
Dim SearchTerm As String = InputBox("Search text in Part Number", "Find text", "Enter Prefix Entry")
	qty = 0
	Dim oPartNumber As String = doc.PropertySets.item("Design Tracking Properties").Item("Part Number").Value
	If InStr(1, oPartNumber, SearchTerm) > 0 Then
'		Dim oPartDescription as String = doc.PropertySets.item("Design Tracking Properties").Item("Description").Value
		For Each innerDoc In openDoc.AllDocuments 'RETURNS NUMBER OF PARTS INSIDE ASSEMBLY, NOT QUANTITY OF INDIVIDUAL FILE
			InnerFileName = innerDoc.displayname
			If FileName = InnerFileName
				qty = qty + 1
				MessageBox.Show("Test")
			End If
		Next
		MessageBox.Show(qty, FileName)
		'save to column
	End If
Next
Thanks a lot for your help. I really want to try out the VBA code you've written.
Felix
Message 17 of 18
Sergio.D.Suárez
what happens is that the code is for rule ilogic, make it run as an ilogic rule and if it is what you need we will see to modify it for VBA, greetings
Mechanical Designer
Message 18 of 18
felix.cortes5K3Y2
Hey Sergio,
Okay I ran it and it works great. Really appreciate the help.
Thank you,
Felix
