Hi @CWC_Drawing_Office,
How many parts will your assemblies have?
In general for Inventor:
- Highest CPU Clockspeed available - usually around 5GHz.
- 16GB RAM Minimum (Higher part assemblies require more RAM)
- 4-8GB VRAM. GPU doesn't strictly matter as Inventor doesn't have significant GPU Acceleration.
The rest is all up to you, however, a bigger battery can be nice. Weight is the biggest compromise as more weight can meaning better cooling (and thus better performance) however it does mean it is less portable. Vice versa for lower weight.
I'd recommend checking out InvMark, which has an online leaderboard: https://invmark.cadac.com/#/
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
