My computer seems to be working fine but when I start autocad it crashes to a blue screen? I've tried updating my graphics drivers and that doesn't work. Does anyone have any ideas?
have you tried looking up the blue screen error code?
DarrenP
AutoCAD forum is over here http://forums.autodesk.com/t5/AutoCAD/ct-p/8
http://forums.autodesk.com/t5/AutoCAD-2007/Getting-blue-screen-on-Autocad-launch/m-p/3576468
Did it ever work correctly?
What version of AutoCAD?
Did you reboot and the problem persists?
Repair install or re-install?
@Anonymous wrote:It had been working correctly for 3 years and it's version 2007.
When was the last time you reformatted your hard drive and re-installed (a lot of garbage builds up over 5 years (or even 3 yrs)).
or
do you have a Windows Restore Point (I always create restore points after installing software and verifing that all is well).
Did you try repair install?
Blue screen only when starting AutoCAD? Blue screen is usually hardware-related, so try re-seating memory and graphics cards. Try swapping out memory modules. Could even be the power supply.
