I have a part that when I try to go into the Generative shape, it hangs up. The only way that I can stop it is to "End Task" in the task manager. In the task manager, the Inventor process is working and the memory usage is going up and up. If I let it run long enough, it will use all my system memory and crash. Here is what I see when I use the generative shape tool.
I have tried to use the Generative shape tool on other parts and it works fine. Its just this part that seems to be causing a problem. I have also tried to copy this part to a new filename. The shape generator hangs on the new file as well.
I have tried:
Rebooting several times.
repair install on Inventor.
opening it in 2018.1.
Any ideas?
Kirk
