1) What resource would you recommend to a noob like myself to better understand and utilize the P&T feature?
2) How does one add parts to the content library to use in P&T?
For example, we use many variations of the push-lok pneumatic fittings and associated tubing. I don't see these included in my library. Same with Tri-clover style fittings. I'm running the stock 2019 but will soon upgrade to 2021.
3) Re #2 above - are third-party libraries that include non-stock components available for d/l ? Something along the lines of Grabcad or 3D Content Central but with complete families of related parts.
Thank you
Solved by CGBenner. Go to Solution.
Hello!
While these are under my old profile, from before I joined Autodesk, these are links to classes I have done at Autodesk University in past years. For the basics, they should still be valid. Hopefully there are at least a few things in these that can help you out. Feel free to come back with more specific questions as you learn and practice. There are a number of T&P users in here who can help you out. Good luck!
Going With The Flow - T&P Basics
Increasing the Volume - T&P Advanced
A Little Less Talk-Tube & Pipe Demo
Authoring & Publishing Custom Content
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
