10:49 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello. I am using the Gear creation command (under the Design Menu in an Assembly file) to create a worm gear / spur gear combination. The gears will be eventually printed out on my 3D printer. However I do not want them attached because then they are printed attached and are not seated correctly therefore unusable. My question is how do I go about separating the gears from each other in the assembly file so I can 3D print the parts out for use in a working model? Thanks for your time.
