G thread type
G thread type
lkirit2000
Advisor Advisor
Message 1 of 15
G thread type
lkirit2000
Hi Team
I came across some G6, G7,G8 .. threads.
I couldn't find the G thread above sizes in the hole - tap feature.
Is this available with any other feature?
Replies (14)
Message 2 of 15
WP_Australind
Would it be referring to a BSP Pipe thread?
Message 3 of 15
lkirit2000
Hi
I couldn’t find the G8 thread.
Thank
Message 4 of 15
WP_Australind
Checking in my Machinery's Handbook 25th edition, BSP threads only go up to 6" BSP.
It maybe aa custom thread, best to check with the original author.
Message 5 of 15
pcrawley
There are a few thread forms (like BSP) with the prefix "G".
Do need a particular thread form?  If so, which one - it will help narrow down the search.
(You're not getting mixed up with geometric limits and fits are you?)
To see all the thread forms Inventor can access, have a look at the Excel spread sheet in:
C:\Users\Public\Documents\Autodesk\Inventor 2024\Design Data\XLS\en-US\thread.xls
Note:  You might need to change the \en-US\ folder to suit your language installation.  Also note that this is the default location of the threads.xls file - you may (probably) have another copy which Inventor reads wherever your Design Data is installed.
If you looking for "GB", it should be here:
If it isn't there, someone has deleted the tab from the working copy of the spread sheet.  Take a copy from the default location and paste it into your working copy.
Peter
Message 6 of 15
lkirit2000
Hi
Thanks for your reply.
I can see upto G6, But I need G8 thread.
Message 7 of 15
pcrawley
If it is BSP threads you are looking for, I don't believe the standard goes above 6" (G6)
See https://www.britishmetrics.com/images/pdf/technical/bspp_bspt_4.htm
Read this Wikipedia page: https://en.wikipedia.org/wiki/National_pipe_thread#Uses - it explains the purpose of theses special thread forms.  Although the page relates to NPT threads, it also applies to BSP threads because they're used for the same purposes.
On the page you'll note: "Commonly used sizes are18,14, ... 4, 5, and 6 inch, as pipe and fittings by most US suppliers. Sizes smaller than 18 inch are occasionally used for compressed air, while sizes larger than 6 inches are often joined by other methods."
I think the G8 refers to something else - not a BSP thread.  If you share the rest of the information about the request, we might get a better idea of what is required.
Peter
Message 8 of 15
JDMather
How do you know that?
Can you show your source of information that indicates this is what you need?
Message 9 of 15
lkirit2000
Hi JDMather,
I have attached spring CAD file.
Message 10 of 15
lkirit2000
Hi
I used my thread gauge to measure that thread.
Message 11 of 15
JDMather
@lkirit2000
Show picture of the thread gauge or link to source of getting one myself.
Message 12 of 15
NigelHay
Another Wiki page lists G threads (BSPP) up to 18".
https://en.wikipedia.org/wiki/British_Standard_Pipe
Message 13 of 15
Frederick_Law
Maybe different standard:
Message 14 of 15
guillermo.martinezC6FK8
Hi
Regarding this issue, Can I add other threads type?
For example NPT, I added this for screw but I would like see this information in this box.
Thank you
Message 15 of 15
Frederick_Law
@guillermo.martinezC6FK8 wrote:
Hi
Thank you
Yes.
NPT is in the files already.
I added AFBMA locknut thread size.
You can see it beside GB pipe thread on my screenshot.
