FRONT VIEW
FRONT VIEW
FRONT VIEW
Hi Everyone,
  I was curious, is there a way to set the cube views at initial sketch creation so I don't have to change it every time I start a drawing.  I always start in plan view but inventor calls it the front.  When looking down the Z axis you are looking from the top or the bottom not the front.
  I know this is trivial but I was thinking about it this morning.
RB
Lewis.Young
I think it's just because Inventor will use the Y-axis as the up direction by default.
If you want to consistently use the z-axis as up, you can open up your template, re-align the viewcube by setting "Current View As" and changing which way the front face is so that z points up.
I'd also change the home view too, otherwise it'll stay as it was before.
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Thanks!!!
Mark.Lancaster
@Anonymous
Another way is to orient the model the way you want and then right mouse click and select create drawing.
2018-09-19_7-48-44.jpg  From there it will create the base view as that orientation.
Mark Lancaster
