I have been trying to freeze a view in a drawing, so that modifiying the ipt wont affect the view. However, in the same drawing there is a table driven by that same table that does need to be updated with any changes to the ipt. Is there any other way then to make a copy of the ipt solely to dive the "frozen views", or to insert a picture?
Hi! There isn't a way to do that for a particular view. But, you can suspend the update for the entire idw/dwg. Simply right-click on the idw/dwg node in the browser -> Defer Updates. Or, go to Tools -> Doc Settings -> Drawing -> check "Defer Updates."
Once this option is turned on, the drawing will remain unchanged as of last saved state.
Many thanks!
Like @johnsonshiue said, there is no ability to lock views. However, you can try the following:
1. Suppress the view (it won't display nor will it update).
When you are ready to consume the updates, you can un-suppress it
However if table is generated off the view, then its a problem
2. Move the view to an inactive sheet so that it does not update
3. Create views and table in different drawings
-shiva
@c_caronBJVAW I did an ideas forum request - this seems to come closest to what you want. Please vote for it and add to it. It does require a project for us to be able to do it, but its worthwhile entering your ideas there.
https://forums.autodesk.com/t5/inventor-ideas/inventor-lock-drawing-view/idi-p/7761683
-shiva
You can certainly add your own requirements or ideas underneath that post if you want to. I meant that implementing this would take a fair amount of time and requires us to schedule an internal development project! Sorry for confusing! 🙂
You are welcome! Yes. Please feel free to add your ideas there. Just so you know that all ideas are reviewed but there is a selection criteria for these ideas based on number of votes, impact and other considerations.
-shiva
