Inventor Forum
Freeform, sizing problem
2 REPLIES 2
adrian_nemethEMC4U
120 Views, 2 Replies
Hello!
My problem is that I can't specify the size of the movement after the edit form command. I reinstalled it, I also increased the DPI settings in the properties (system extended), but it doesn't want to be solved. Could someone help me? (I marked with a red square where the size should be entered!)
Thank you in advance for your help!
Hello Adrian!
2 REPLIES 2
Hi Adrian,
This could be a dual monitor or screen resolution issue. Please try the following and see if it helps.
1) Go to Windows Display settings -> select the recommended resolution and scale.
2) Right-click on Inventor desktop icon -> Properties -> Compatibility -> "Change High DPI settings" -> check both boxes.
3) Go to Control Panel -> System -> Advanced System Settings -> Environment Variables -> create the two variables.
a. "QT_AUTO_SCREEN_SCALE_FACTOR" and set it to 1.
b. "QT_SCALE_FACTOR" and set it to 1.
Many thanks!
Software Test Engineer
Hello!
I did the advice you gave, but unfortunately it doesn't work either! 😞
Technology Administrators
