freeform not visible after editing
Message 1 of 11
I have following problem:
If I want to edit the freeform it gets unvisible. Last time i edit it, it works normally.
I opened the file and a backup version at different PCs but it does not work.
With other parts it works normally:
Best regards
Niels
Replies (10)
Message 2 of 11
S_May
Welcome to the Forum, can you attach your attempt for us to try (PDF, BMP, IAM, IPT...)?
Message 3 of 11
Yes
Message 4 of 11
TheCADWhisperer
Message 5 of 11
mdavis22569
Shows for me:
Make sure this isn't checked:
Mike Davis
Message 6 of 11
S_May
Hi @Anonymous,
everything is ok on your model, please see the settings Smiley Wink
beautifully built, what do you construct
Message 7 of 11
Thank you for your awnsers but this does not help.
I attached a video, at the first part it does not work, at the other it works normally.
We checked it on more other PCs, at 5 of 9 it does not work.
The part is a half cut of our Bodywork of our Formula Student racecar.
Message 8 of 11
mdavis22569
That's odd ...do you have 2018.2 installed?
I have a Deutsch version on my PC I'll try too ...
Mike Davis
Message 9 of 11
Ok,
at the PCs with inventor 2018 version 1 and  0 is does not work only at the PCs with the new Version 2 it works.
That seems to be the problem.
Message 10 of 11
mdavis22569
So we're on to the issue ...
I have all of the updates installed... as I'm sure JD does as well...
Mike Davis
Message 11 of 11
TheCADWhisperer
@Anonymous wrote:
Ok,
The first thing I did was check the iProperties for the file (which indicated 2018.2).
It never occurred to me that you were trying to view the file on an older release.
