Free Rotate not working in assembly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an problem with Free Rotate not working in assemblies. I highlight the part/ subassembly, select free rotate from the pop up menu, the circle appears around the part but when I attempt to rotate it the whole assembly rotates as if I was using orbit.
I have tried deleting and re-inserting, I have shut down Inventor and checked for updates and restarted the PC. I have ungrounded all other parts in the assembly. None of this makes a difference.
This has happened with both a multi part sub assembly and with a simple rectangular flat plate.
But it does not happen with all parts and I can find no correlation between which ones work and which don't.
My assembly will use the same part in different orientations so its helpful to be able to rotate them before I constrain them.
My work is proprietary so I cannot upload directly to the forum.
