Inventor Forum
Frame Generator
2 REPLIES 2
lhoggeth
887 Views, 2 Replies
Frame Generator
Hope you can help me with this.
I want to use ASME B36.10 10m pipe 3 sch80 on 'Frame Generator'.... how do I proceed with this? I can't find it under the 'standard' list ?
Many thanks
Lee
2 REPLIES 2
BDCollett
in reply to: lhoggeth
Frame Generator uses Structural Shapes.
ASME B36.10 10m pipe is to be used in Tube and Pipe.
You could make a custom library and create your own Pipe that could be used in Frame Generator if you wanted or just use ANSI ASTM 3x0.3 which would be basically the same.
lhoggeth
in reply to: BDCollett
Many thanks
