Hi everyone
As you can guess from the title this post is about the frame generator. At my current job I need to draw things like guards, handrails etc. And I've to use inventor due to circumstances.
So the first thing, the part numbers inventor generates are not what I, nor the workshop likes to see. So I guess the best thing to do is to copy, paste and edit in the main assembly BOM. The part number set by inventor is what I'd like to see as a description. This is nothing I can't overcome, it just makes things a bit more manual. And from what I've gathered from googling this topic, it's kind of the easier and faster solution (read little set-up time). But if it isn't feel free to shed some more light on this subject.
The other thing that really bothers me is drilling holes in frame members. The holes need to be drilled at member level, not in the assembly. I can do this quite easily if I can use the "reuse frame member" function. That way I make 1 member and reuse it across the assembly. It isn't the best function but for small assemblies and straightforward parts it works.
But now I need to design a handrail, which is divided into different sections for transport. Across these sections I use the same piece for the vertical struts, some with mounting holes and some without. The first thing I don't like is that I need to manually differentiate between one with holes and one without. Inventor doesn't recognize a difference since it generates the part number with length etc. This makes it easy to make mistakes. And to add on top of that I can't reuse the frame members either, so I've to drill the holes in each frame member separately, in every subassembly. If you try to demote members you've reused they stay grouped and all move to a single sub assembly.
So now my question is what is the correct workflow to tackle this problem? I hope my explanation is understandable.
I'm currently using inventor 2016, but I'd be happy to hear if 2017 has improvements.
