FRAME GENERATOR WEIRDNESS
kadscad
Message 1 of 18
kadscad
I was having issues with frame generator placing the chosen profile in different orientations even though in therory they should place in exactly the same orientation.
So I created 4 identical wireframes but I start each box from a different corner.
I went along the top row and place all the pieces
Then I went along the bottom and placed the same profile adjusting the orientation as needed and proceeded down the row.
Next, I did the same for the 2 verticals choosing all the left and then coming back and choosing all the left.
I started every sequence from the left-hand box over to the right.
As you can see even though my setting were identical for each horizontal or vertical the outcome was not consistent.
Yes, I change the start point and rotation as the need for the first box and work right.
WHY are the profiles being orientated differently
Kirk
Inventor 2023
Accepted solutions (4)
Replies (17)
Message 2 of 18
Mark.Lancaster
@kadscad
You need to provide all the files (like T1.iam) associated to this model.  An assembly file only contains the links to the components.
Also when you share files you need to provide us with what version of Inventor you're using.   In your case is the original Inventor release of 2018.
Mark Lancaster
Message 3 of 18
kadscad
Thanks Mark for the heads up. I'm a newbie to Inventor. I will forward these over asap
Kirk
Inventor 2023
Message 4 of 18
kadscad
Mark were you able to see the weird outcome in the pdf?
Kirk
Inventor 2023
Message 5 of 18
hncarle
This is something I discovered way back in 2016.
When you choose the line the orientation is dependent on WHICH END YOU CLICK CLOSEST TO.  If you pick the left end of a line the frame will be oriented one way.  If you pick the right end of the line the frame will be orientated OPPOSITE!  Quite annoying or quite useful depending on if you are paying attention.  LOL
So solution is to always click near the same end of the line as you go around the frame.
I'll make a screen cast later if I'm not being clear.
Message 6 of 18
hncarle
Ok here is the screen cast. Hope this helps.
Message 7 of 18
hncarle
Oops maybe not.
Message 8 of 18
hncarle
Third time the charm?
 Ok will wait for youse guys to post instructions.  It has been over a year since I posted a screencast.
Message 9 of 18
kadscad
No your perfectly clear, but that needs to be fixed. I thought it might have something to do with the direction of that the lines or rectangles were placed.
Kirk
Inventor 2023
Message 10 of 18
Mark.Lancaster
Sorry for the delay in getting back to you @kadscad
IF it was me, before I placed any frame members, I would right mouse click and select chain select or by a given sketch..  If you do the given sketch you can apply the same frame member and orientation to all the sketched lines with a single click...
Mark Lancaster
Message 11 of 18
kelly.young
Autodesk Support
Autodesk Support
Hello @kadscad the easiest way to share parts is to use Pack & Go as .zip to ensure that all files are gathered.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 12 of 18
kadscad
Kelly No need to pack n go now. I was enlighted that if I chose a different of a line I will get different results.
That's a bug in my opinion
Kirk
Inventor 2023
Message 13 of 18
kelly.young
Autodesk Support
Autodesk Support
@hncarle here's a quick screencast showing how to embed within the post.
Message 14 of 18
hncarle
Yeh I did that several times.  Apparently when they send an e-mail that it is ready to review the file hasn't actually been posted yet.  I looked in my profile and it didn't show as ready.
Oh well live and learn.
Message 15 of 18
doug.johnston
Just to add my observations / thoughts:
I've noticed that placement of the members can also depend on the orientation of the model based on the UCS.
If your view orientation is different from the "normal / Home", then the members tend to get placed in different locations.
I've gotten into the habit of placing all my frame members in the center of the member, then go back and orient them to the side / location I want.  I also edit the members 1 by 1 after building the entire frame first, so moving them after doesn't slow me down … it's just part of my workflow.
It's not easy maintaining this level of insanity !!!!!
Message 16 of 18
kadscad
You are exactly right, it's not easy maintaining this level on insanity but someones got to do it
Kirk
Inventor 2023
Message 17 of 18
jan_priban
seems to be resolved/answered. Yes, orientation depends on beam "end"/"half" you select. See please video - 2018-09-07_11-47-12.mp4 . Skeleton is just sketch with line + line pattern. Just 6 lines
Notice how I placed T-shapes. First 4 I  selected top "end"/"half", Last 2 (5,6) I selected bottom "end"/"half" => different orientation than beam 1-4
Regards
Jan Priban
Message 18 of 18
SBix26
I wish there were some way to get a better indication of what will get placed in which orientation.  It's easy to see when it's a T-shape, but not at all easy for square tubing, square t-slot extrusion, or worst of all, round tubing.
It doesn't matter for those shapes until you make end treatments (miter, for example), and then try to reuse members.  It requires trying multiple times and clicking in different locations to get them to place in the proper orientation.  I haven't been able to figure out a reliable method.
Sam B
Inventor Pro 2019.1.1 | Windows 7 SP1
LinkedIn
