- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was having issues with frame generator placing the chosen profile in different orientations even though in therory they should place in exactly the same orientation.
So I created 4 identical wireframes but I start each box from a different corner.
I went along the top row and place all the pieces
Then I went along the bottom and placed the same profile adjusting the orientation as needed and proceeded down the row.
Next, I did the same for the 2 verticals choosing all the left and then coming back and choosing all the left.
I started every sequence from the left-hand box over to the right.
As you can see even though my setting were identical for each horizontal or vertical the outcome was not consistent.
Yes, I change the start point and rotation as the need for the first box and work right.
WHY are the profiles being orientated differently
Inventor 2023
