Inventor Forum
Frame Generator: Resizing frame members loosing all modeling works
6 REPLIES 6
tobias
374 Views, 6 Replies
I have a frame made out of round steel tubes. The thickness is 8 mm and it has to be changed to 10 mm.
In the tube are some holes and cut-outs. Now, when I modify the frame member by "edit with frame generator" all my modelling works are gone because FG is replacing the part with a complete new part.
Any ideas /solutions ?
Tobias
The Netherlands
Inventor Pro 2025, Vault Pro 2025, AutoCad Electrical 2025.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Tags (2)
6 REPLIES 6
CGBenner
in reply to: tobias
@tobias
I just tested this in IV 2023 with a hole added at the Part level, and another hole added at the Assembly level.  I then changed the size of the tube (wall thickness), and generated a new part.  Both holes were still present.  Are you seeing different results?
Chris Benner
Industry Community Manager – Design & Manufacturing
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
tobias
in reply to: CGBenner
@CGBenner ,
Good to know. Indeed I'm seeing different results. None of my holes and cut-outs are present anymore.
Did you changed the thickness /size with this menu ?:
Or on the parameters ?
Tobias
The Netherlands
CGBenner
in reply to: tobias
@tobias
I used "Edit with Frame Generator" after selecting the tube and Right Mouse clicking.  In my image below you cannot see the tube I selected because the pop up menu covered it.
Chris Benner
tobias
@CGBenner ,
I will make a test file and let you know. To be continued...
Tobias
The Netherlands
tobias
@CGBenner ,
I made a test file and it worked like you said. My mistake was the following:
When editing the frame member I also modified the family (same catogory) and that doesn't work.
So for now I leave the family alone (unfortantly) and just modify the thickness.
Thanks for your help!
Tobias
The Netherlands
CGBenner
in reply to: tobias
@tobias wrote:
@CGBenner ,
I found the same as you when changing the family.  It's too bad that doesn't work the same way.  Maybe this is an enhancement request?  I'm glad this worked for you, at least a little....  Have a great weekend.
Chris Benner
Technology Administrators
