- Mute
- Permalink
- Report
I am using frame generator to create a welded handrail framework. I have a 2d sketch that the component parts are attached to. I need to move it off centre by 25mm in the X and 1" in the Y, this is not a problem, it is the direction that the part moves.
(See image)
I have used the align to align it with the top of the post. The organ line is the blue line on the right.
If you look closely at the gold arrows they are not aligned with the RGB arrows.
The only way i have found to get around this is to measure from a plane in the round part to somewhere that it flat, ie top of post. and ad this angle to the rotate in frame generator change box.
It seems to me that the theoretical Z of the line is not perpendicular to the plane it was created upon (if that makes sense)
Does anyone know of a way of setting the organ direction that the parts moves?
Win 10.21H2.19044.2604 - IV2022.2.2 - Hardware beats min requirements.
