I want to use the notch function on a beam that is crossing several other beams, in this exact case there are 4 notches. When I use the function, only two of the notches gets created. When I try to create the ones that did not get created the first time, there is still only two notches afterwards. Sometimes the existing notches gets replaced by the new ones.
The odd thing is that two of my colleagues have tested to do the same with the same file, and it works just fine on their computer.
I have added a picture with a test file, and it shows 4 crossing beams which all was chosen as a notch tool. But it only used two of them as you can see.
Does anybody have any tips to what can be wrong?
We recently upgraded from 2020 version to 2024 in our company if that is of any help.
Solved by roger_nevestveit. Go to Solution.
Hi Roger, this is a defect, we are tracking it internally under INVGEN-80369
