Frame generator notch issue
roger_nevestveit
roger_nevestveit
I want to use the notch function on a beam that is crossing several other beams, in this exact case there are 4 notches. When I use the function, only two of the notches gets created. When I try to create the ones that did not get created the first time, there is still only two notches afterwards. Sometimes the existing notches gets replaced by the new ones.
The odd thing is that two of my colleagues have tested to do the same with the same file, and it works just fine on their computer.
I have added a picture with a test file, and it shows 4 crossing beams which all was chosen as a notch tool. But it only used two of them as you can see.
Does anybody have any tips to what can be wrong?
We recently upgraded from 2020 version to 2024 in our company if that is of any help.
Replies (20)
blandb
As it sits right now, you model has 5 components. Each shortened yellow piece should be separate. If the yellows are all going to be the same, just place 1, notch and reuse.
Autodesk Certified Professional
blandb
you are trying to split 1 yellow part into 2 parts with a notch it appears
roger_nevestveit
I am trying to split it into 5 pieces in this example, but I am only able to split it in maximum 3 pieces. On my colleagues' computer it works as usual, so either there is some setting in my computer or there has been a fault with the installation when I did that not long ago.. I guess.
blandb
The notch tool may visually look like it is breaking it up, but it will not physically break that member into 5 pieces. That beam is still 1 file on disc, it is still (1) solid body). If you are wanting individual files, you need to place the end once, and reuse (if it is to be the same) and then place 1 middle and reuse (if they are to be the same).
James_Willo
Hi Roger, please attached the files and assembly of your image so I can have a look.
Thank you
James W
Inventor UX Designer
roger_nevestveit
I can't upload more than 3 files in one post, so I will post 3 times.
Thanks.
roger_nevestveit
3 more files.
roger_nevestveit
3 more files
roger_nevestveit
And now that I have given it 2 more seconds of thought, I have added a zipped file with all files.
roger_nevestveit
Yes, this is true. In this particular file this can be a solution, but in my real case the two beams in the middle are smaller RHS profiles that goes through the HEA beams. So I am trying to notch the longitudinal beams with the RHS beams as notch tool, but when I do this the notch against the other beams disappear, leaving a maximum two notches left. Or sometimes it only notches around one of the RHS beams and keeps one of the notches against the other HEA beam. It really does not make any sense...
James_Willo
Are you trying to achieve this? Works fine on mine (2024.3)
James W
James_Willo
Files attached
And video
James W
blandb
That makes sense
roger_nevestveit
Yes, this is what I am trying to do. I have uploaded a video of what happens when I do the same as you.
James_Willo
Did you update to 2024.3 just in case it was a bug that's been fixed?
James W
roger_nevestveit
Yes. It says:
Build 343, Release: 2024.3 - Date: Mon 03/18/2024
johnsonshiue
Hi! James and I tried the workflow on 2024.3.2 and 2024.3.1. It seems to work fine. Please take a look at the attached file. Please install all critical Windows updates and the graphics driver. Then install Inventor 2024.3.2 update.
Many thanks!
Software Test Engineer
roger_nevestveit
Hi everyone.
I found the solution. In the dialog box for the notch tool, there is a drop down menu in the top right corner (Advanced settings menu). Here there is one setting witch can be turned on and off named "Delete existing end treatments". This setting was ticked on. When I ticked it off everything works just fine. I don't understand the logic behind it, but that was the case.
Thanks for the help anyways 🙂
James_Willo
Glad it works, but I don't think this is the correct behaviour. You'll notice when delete is on it deletes the original notches and recreates them. When it's off it just adds two new ones. I believe the idea is that if there is an existing treatment that would cause a failure, for instance it tries to put two notches on top of each other or mitres it will delete the original to stop it failing.
I will ask a developer about this.
James W
