Hi, I'm trying to set up the frame generator to start naming things in a convention that we're used to which is essentially naming things <Assembly Name>_Item1, Item2_, ... , Item12, etc... and was wondering if a convention like that is possible with the index number. From what I've seen the index number setting <Index Number:001:1> would give you an index value from 1 to 999 but item1 would be called item001. Is it possible to have it only use 1 digit for 1-9, then 2 digits for 10-99, then 3 digits for 100-999?
Solved by blandb. Go to Solution.
Can you not just make it like so:
<Index Number:1:1>
This appears to do what you want:
Thanks, for some reason I thought the 1:1 was indexing value and maximum value. Oops...
Thanks for the help
