Inventor Forum
frame generator issue
4 REPLIES 4
kaomar23
324 Views, 4 Replies
hi dear inventor users
i have a question related to a frame generator i would be very gratefull for your valuable contribution and help
im designing a frame for a machine and had an issue: i dont know what happened but all the frame members are now with an "i" before each member and with the message: frame member is referencing to a no existing geometry and i cant delete each member and re generate each one its very tedious
so im wondering if there is  a way to restore the link between each member and its geometry
many thanks
4 REPLIES 4
SharkDesign
in reply to: kaomar23
I'm going to guess that you have deleted or moved your skeleton model.
Frame generator is really particular about how it is set up.
  Expert Elite
  Inventor Certified Professional
SharkDesign
Here is the setup for a frame:
The 'container' as I call it, is the main assembly, this is what you should insert into the top level assembly.
The frame sketch is your sketch that defines it. DON'T DELETE THIS. This will cause your members to get a blue i.
The frame assembly contains the skeleton and the frame members. This is a new assembly is created in your job folder, don't insert this into your top level assembly.
The skeleton is created by inventor and lives as another part in your job folder. DO NOT DELETE OR MOVE THIS.
The frame members sit at the bottom.
If you have deleted or moved the two files I mentioned above, this destroys your frame.
If you can put them back, you may be able to save it, but if you've deleted them out of the assembly itself you are knackered.
  Expert Elite
kaomar23
in reply to: SharkDesign
thanks for your answer but i didn't move or delete nothing it happend once i have added a member
thats it
SharkDesign
Can you attach a screenshot?
Or better still attach the assembly and files.
  Expert Elite
Technology Administrators
