Frame Generator Interface
timothy_berg
timothy_berg
I've lost the Frame Generator command interface, all other commands the interface is shown and works. Any ideas?
johnsonshiue
Hi! The first thing to check is Add-In. Go to Tools -> Add-Ins -> do you see Frame Gen and other Add-Ins? Load them. If you don't see them listed, it means you have installed Inventor, not Inventor Pro.
Many thanks!
Software Test Engineer
timothy_berg
Frame generator is checked on the Add-Ins list.
johnsonshiue
Hi Timothy,
That sounds strange. Maybe you need to either reset Ribbon or reset Inventor. You can right-click on the Ribbon panel -> Reset Ribbon. Or, use Inventor Reset Utility (All Programs -> Autodesk -> Inventor 2020 -> Tools) to reset all settings back to install default. You may lose your prior UI customization.
Many thanks!
timothy_berg
I think it had something to do with the video card, this was never resolved due to my IT department changed computers.
Thanks for the help.
