Frame Generator -> Dynamic Simulation -> FEA: Is it possible?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I'm trying to use Inventor Frame Generator to generate two frames, constrain the two frames together leaving one degree of freedom between them (axis rotation), use Dynamic Simulation to calculate forces imparted on the frames in various scenarios, then export those forces into FEA for analysis / validation. It think this all sounds reasonable, right? But I can't seem to get it to work no matter what I do. The simulation runs without problem, but the issue is that the export to FEA step rejects selection of the frame subassembly, saying it needs to be set to Flexible to be exported. However the generated frame assemblies and their containing assembly are set to Flexible and everything I try results in the same error message. I was able to throw together a few parts into a flexible assembly and get simulation -> FEA to work, but it only works for a single part in isolation. This is somewhat useful, but I really need to see the FEA results at the frame assembly level, not just individual parts. The solution seemed to be to derive the two generated frame assemblies into two parts, constrain them together in the same way, simulate, and export the frames (now as parts) to FEA. However, for some reason this results in the same - even though the assembly is set to flexible and only contains parts (not assemblies), the export to FEA step generates the same error that the assembly needs to be flexible even though I'm selecting (derived) parts. This happens no matter how I derive a frame to a part - single-body, multi-body, etc. Am I doing something wrong here? Can someone (Autodesk?) please post an outline of the steps to take to do FEA analysis of frames where the loads are generated by dynamic simulation?
