Frame Generator Frame Member Save As
Message 1 of 8
Is it at all possible and easily performed to save the Frame Members that are generated from the Frame Generator as a weldment.iam?
So essentially what I am looking to accomplish is this:
FRAME MEMBER: ANSI 4 00000001:1 and ANSI 4 00000005:1 would become 27740-001.iam
Replies (7)
Message 2 of 8
Curtis_Waguespack
Hi Justin74VSP,
I think what you want to do is just demote those members.
I hope this helps.
Curtis
Message 3 of 8
Thank you for your response!
How would I then convert it to a standard part but leaving the cut features?
Message 4 of 8
stuart_smith82
Edit! Just realised you only wanted a selection to be 27740-001.iam. As Curtis has stated you could use demote. If you wanted to create one parts you can still use the workflow from the link below.
I assume you only want to see the one item and no sub components in a structured assembly showing multiple levels? If you are creating a parts only parts list it will already be 27740-001.iam.
If you are using a structured parts list and want one item you would have to derive the assembly into a part:  https://knowledge.autodesk.com/support/inventor-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/I...
Stuart Smith
Group Data Management Consultant Graitec UK
[email protected] | www.graitec.co.uk
Blog: https://www.graitec.co.uk/blog/blogger/smith
Graitec Manufacturing Blog: https://www.graitec.co.uk/blog/categories/mechanical
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Message 5 of 8
Mark.Lancaster
@Anonymous
Frame generator components are standard Inventor part files.   Not sure what you're asking here..  Can you clarify?
Mark Lancaster
Message 6 of 8
Sure, I would be glad to. The way the process is set up to release prints to production once quoted requires each individual piece part to be a separate and unique part number. I cant just do a sketch in a weldment file and then go crazy inserting frame members then trimming them accordingly. Its a round a bout way to do things, I know, but its the nature of the beast.
Message 7 of 8
Curtis_Waguespack
Hi Justin74VSP,
See these links, I think between the 2 of them you should be able to get closer to what you're after:
http://inventortrenches.blogspot.com/2011/03/detailing-frame-generator-weldment.html
http://inventortrenches.blogspot.com/2011/03/understanding-autodesk-inventor-frame.html
If you still have questions or I've misunderstood just post back.
I hope this helps.
Curtis
Message 8 of 8
Curtis_Waguespack
