To solve that dilemma, I just created my own CC from scratch.
That involved iProperties and part geometry, primarily.
For example, in out-of-the-box Inventor, a CC part's I-beam profile sketch geometry would be mirrored. Who's the bureaucrat that decided to do that?! Mirrored geometry is very difficult to manage downstream in non Frame Generator applications. So, I REMADE ALL THE PROFILES SO NONE OF THEM HAD MIRRORED GEOMETRY IN THEM!
Then, I wanted to have all the iProperties the same throughout the entire CC, so the BOM would be easy to sort and the Parts Lists on drawings would be easy to format and edit if necessary. As a result, I spend very little time editing the BOM and Parts Lists, which formerly took HOURS PER PROJECT!
It took a few weeks to accomplish all of this reworking of the CC, but the savings in time, energy and ERRORS has been amazing over the years.
Too bad Autodesk didn't establish a GLOBAL STANDARD when they first created the CC!
Anyway, all one has to do is to work up an exhaustive list of possible iProperties that all standard CC parts could possibly have, and then standardize them across the board. For example, the pipes have PL for part length, but most of the structural shapes have G_L. So I just made the pipe length G_L too. That way, G_L MEANS LENGTH ANYWHERE IT OCCURS IN INVENTOR. Same with all the other iProperties. I follow the KISS principle: keep it simple stupid!
Then for all the other stupid defects that Autodesk refuses to fix in the CC I sought help in the Customizatuon forum for making iLogic rules to fix those errors as they occur. For example, one such error is a change in UNITS FORMAT for dimensions in a CC part when a FG frame member is swapped out for another size or type. In a large model, that can wreak havoc on the BOM/Parts List as well as run up the costs in time and energy to fix. But a simple iLogic rule can change all that. I got one from @jtylerbc that I put in every CC part that fixes the length UNITS in the members that get broke. It 'fires' every time the part is saved. That particular problem really screwed me for many years until I began delving into iLogic. Some Inventor DEFECTS you just need to bite the bullet and use iLogic to solve.
Anyway, that's my view on uniformity in the CC for down-stream benefits all around.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
