Hello Everyone.
I have been playing around with Inventor (moving across from Solidworks) and am wondering how I 'detail plates' I am becomeing familiar with the Frame Generator to create all of my members, but it seems quite disconnected in the creation process create a plate.
I currently am creating the 3D sketch (in a part) creating the (base) plate in the same part and then in the assebley I am using the frame Generator (See image) to create the members.
Does anyone have a tutorial showing how to correctly include the plates as part of the design process.
Ashley
Solved by brendan.henderson. Go to Solution.
Sounds like you want the base plate to reside within the F-G assembly. Only items created within the F-G can reside within the F-G assembly. One could "Author" a custom CC part that would be your Base Plate.
On small assemblies such as what you posted, I would use a standard IAM environment and bring in my structural parts directly from the CC.
I am not sure I follow,
Did you mean, model everything as single parts (so each member) and bring them into the assembley? or is their another way?
For simple assemblies like the picture you posted, I wouldn't use the F-G.
Just start a new IAM.
Create your Base-Plate
Then for each of the structural members just place them from the Content Center and constrain them as normal parts.
You can chance size and length of the C-C members by simply RMB on them within the IAM and selecting the Change from the dialogue box.
I think this is a function that should be in Inventor so I added it to the wishlist.
I found an add-in that does exactly what you want. About $1200 AUD per seat. Does a great job of foot plates and beam joining plates and chamfer plates and all sorts. Here is the website http://asi-profile.de/englisch/product/demo_videos/. Have a look at the CREATE PLATE JOINTS video.
Only troubles are :-
